Wobble
Auto Art Ford Gt
This arrived in the post today. Funny thing is the bloke on Trademe had advertised it as Scalextric and I thought at $30 new and unused it was OK.
Turns out it was new but not a Scaley so I decided to have a look anyway. Chassis didn't look too bad and should be alright to tune a bit
Front tyres sanded quite easily, rears would be NSR so I added a couple of O-rings to give the tyres something to park against
Standard gearing is 12:38 (3.166) so a SRP 18k motor was the go with NSR 12 tooth plastic pinion (same size as AA pinion and sounds as good as the standard gears if not better)
NSR 5208 trued to 22.2mm which is still quite a large tyre so it should suit the motor and gear ratio. 5-6 gms up front and 98gms all up.
Just in time for 1st run tonight and I wouldn't be surprised if it goes better than both my Scaley versions.
Auto Art do make a great looking car, some run well others not too well but that's pretty much like most brands anyway.
I haven't seen the 'o' rings used before, I take it you are using them to fill the tyres more?.
Matt this is my 5th AA car, I've got an Alfa GTA and Lambo Muira and they go really well, also I've got a D-type and C-type and the C isn't too bad for what it is. Both have 14k motors but it's still almost too much for the D-type.
The O-rings are a gap filler because the centre ridge is 2mm and the NSR are for 5mm I figured it would be easier to get the tyre sitting square on the hub
Edited by Wobble
Nice work as always Wobble
2019 NZ RTR Nationals Gt 3rd
AA cars could be a bit under-rated by some.
It looks like Bram has it well under control though.
Just ordered a Miura myself.
all cars have potential and can go well with the right tuning
Holdens rule the rest just drool
slot cars are my drug,
ATCC/Bathurst proxy host
NZ Grp5 proxy host.
Cheers Bram,
I have a few of the Auto Art cars myself and quite like them.
They run quite well on the home track even with only a little tuning.
Nice work, Bram.
Ok - for the electronic guru's on this forum... those capacitors.
Most models I see only come with one - across the motor lead tags.
I note with this model, along with all the Carrera models I have - it employs 3.... one across the brush tags and one from each tag to the motor casing.
Can someone kindly explain the relevance of the additional two ceramic caps please?.
My understanding is that these little ceramics "filter" and smooth out the short gap in commutator as the brush "bridges" from one armature field to the next - and helps to avoid voltage spikes and burning across the commutator - but can make no sense in why we would want to send it to the motor casing as well... I don't believe it is electrically connected to the commutator... unless, perhaps by doing this we are making some form of storage to the motor shaft through its bearings... it's beyond my puerile understanding in electronics.
John, I've got a set of MJK's for the Muira if you want them, funny hubs have different diameters each side as well as the centre ridge being bigger.
ps it goes way better than I expected. The key to an 18k SRP motor is taller gearing. Tried 1 in a Scaley Mustang and even with 12:36 it ran out of revs and stopped on a dime.
Edited by Wobble
You've done well there.
"Winning" as the young folk would say.
A wise man once said... "Its not the mistakes you make , its how you respond to them that matters."
(It wasn't me)
I have done a few AutoArt cars and had some good results. The 911 GT3s were available for nine quid ex UK for years and were a great platform to work with. One of the real bargains of the last few years. I have 4 waiting to be set up like your GT40 for a club enduro.
Podiums are for short people.
It is so you can have practice with your sidecutters
Nice looking car. I like the O-ring tip too. Do you also true the O-ring down to the dia of the hub's centre ridge?
They are only toys .... until you pull the trigger.
I think the extra two caps are just to ensure that any spikes from the brushes are filtered via the can.
Autoart seem to go over the top with filtering, a choke in both wires and the three capacitors.
I am just wondering why you changed out the Red stripe motor?
Was it to suit club rules?As the red stripe goes very well.
I find that the biggest issue with the autoart motors is not that they are 24k, it's that they have too little brakes.
As such, my Countach is much quicker laptime wise with the 18k Carrera fitted than it was with the stock motor.
yep I agree Phil, I like the red stripe motor and run one in a Slot.It Toyota Group C car and it can easily keep up with the orange end-bells and win races, but for this I wanted a 'true' 18k with more torque and better brakes, because it's a bit weighty, for our 18k GT class.
s_r I've been looking for a Countach for ages, it seems they're like hens teeth now
Edited by Wobble
sorry Pat, I missed your post ... no, I didn't bother trying to true the O-rings as they didn't put too much of a lump in the tyre, could've used slightly smaller ones but it was what I had
I've just been going through some of my cars removing heads of driver figures without helmets to send to munter to get some copies made.
Here's the dash of the AA Ford GT. Just thought I'd show it 'cos I think it's pretty impressive. Trouble is I couldn't even make it out without taking a photo with macro to see the detail.
Sorry bro' can't see what station it is tuned to.
