tonka500 Posted November 29, 2014 Report Share Posted November 29, 2014 Hello, This might be like asking how long is a piece of string. But anyway, is there an approximate corner radius where cars can be driven flat out around? I'm planning a 3 lane routed track and want to go with big sweeping corners, but also don't want them so big you just hold the trigger down the whole time. It will be no mag and most corners will have a slight positive camber. Biggest radius corner I'm looking at so far is about 750mm (giving a 1500mm diameter). Types of cars run will range from the SCX old school rally cars (Renault 8) through to faster stuff like Slot.it group C. It might be that the radius where they can be driven flat out is 3 meters or so and I'm worrying about nothing but just wanted to check. Thanks for any advice! Andrew Quote Link to comment Share on other sites More sharing options...
Ember Posted November 29, 2014 Report Share Posted November 29, 2014 At a guess, I'd suggest it depends on the car. A low, wide Group C is going to take a long sweep better than a tall narrow classic rally car. Quote Computers. They'll never catch on. Tiny Tyers Targa - The build saga continues - Aging wood - A recipe for staining wood - Don't take a fence - Step by step paling fence - An old shed for my new cars - Wooden garage under construction Link to comment Share on other sites More sharing options...
32coupe Posted November 29, 2014 Report Share Posted November 29, 2014 On my routed track I have a 1700 corner at the end of a long strait, and yes you have to brake on entry and feather the throttle all the way around. So my advice, go for it. Cheers Andrew Quote A man without a woman is like a neck without a pain. Link to comment Share on other sites More sharing options...
slotbaker Posted November 29, 2014 Report Share Posted November 29, 2014 A little bit of banking in the turn will allow higher speeds. But as Ember says, depends a great deal on the car. The track surface might have something to do with it as well. Quote Steve K. Link to comment Share on other sites More sharing options...
difinity Posted November 29, 2014 Report Share Posted November 29, 2014 Back when I raced 1/24 wing cars at Hornsby etc, iirc, the big banked 8 lane track had a corner about 7-8 feet inside radius. Could just about get around that flat out without backing off. Not if the car was a hard body though. That was about a 30 degree bank too. I reckon use your 1.7m and have some fun. Will still need to drive through... Quote Link to comment Share on other sites More sharing options...
tonka500 Posted November 30, 2014 Author Report Share Posted November 30, 2014 Fantastic. Thanks for the replies everyone! Quote Link to comment Share on other sites More sharing options...
