ZeGas 65 Report post Posted December 15, 2013 Haven't come up with a decent name yet so this is it for now. If anyone can think of a better name I'm all ears. This is in the planning stages only at the moment, hopefully start the build in about 3-6 months, sooner if at all possible. Here is the initial plan, it has gone through many iterations to get to this stage, 2 lane and 3 lane options. I finally settled for 2 lane analog. Overall each lane is 27.83m long. Track width 200mm, hopefully wide enough for 1:24 if I choose in the future. Headroom for tunnels min 100mm, high enough for trucks. The tightest corners has 200mm radius (inside lane). Each corner has a 2x radius lead-in/lead-out, i.e. if 200 radius lead-in/lead-out will be 400mm. Overall width - 1.0m for front and 1.5m for the side. Overall length - 5.8m and 2.2m for the side. The dashed line in the top right is a barrier as I don't think I'll be able to reach there to put cars back on track The sweeping corner above this will have 15 degree camber so in effect the straight will be 5.96m for the yellow lane & 6.12m for the red lane. The rise up the mountain is 600mm. Direction is intended to be left to right along bottom straight, I don't think it would work the other way as the drop down the mountain would be too steep for the cars to stay on track. I made three mock-ups 1:10 of 1:32 so I guess 1:320 scale of the various options I have been playing with, the first one was a two lane with banked curve at top right of image, the second was a three lane version of the first. If anyone is interested in either of these I can supply cad file, I won't me making these. This ones the winner in my opinion. Quote Cheers Grant ....................................................... Home Track..........Corvette C1 Build..........McLaren M1A Build..........Maserati 300S Build..........Allard J2 Build..........50's Diner..........Iso Griffo A3C 3D Printed Adjustable Chassis..........3D Print Projects If life gives you lemons, take them, free s#!t is cool. Share this post Link to post Share on other sites
digby 1 Report post Posted December 15, 2013 Nice job ZG, Have you run a few matchies around it just to check the lines , or is that for the 25th.Looking forward to seeing the full size track . regards digby Quote Share this post Link to post Share on other sites
32coupe 20 Report post Posted December 15, 2013 HI Nice design, one thing though, 200mm is too narrow, you will need at least 80mm-100mm to the outside of corners or you will find cars will hug the rail and be able to corner flat out and not come off, giving the outside lane a major advantage over the inside lane. Cheers Andrew Quote A man without a woman is like a neck without a pain. Share this post Link to post Share on other sites
Ember 71 Report post Posted December 15, 2013 There are some sections of it that I love for both the scenic potential and the driving potential. Quote Computers. They'll never catch on. Tiny Tyers Targa - The build saga continues - Aging wood - A recipe for staining wood - Don't take a fence - Step by step paling fence - An old shed for my new cars - Wooden garage under construction Share this post Link to post Share on other sites
ZeGas 65 Report post Posted December 16, 2013 Digby, no matchies, Mockup is 1:320 scale not 1:64. Might make something out of clay or something and see what happens. Andrew, The measurements you mentioned, are they for 1:24 requirements, the track is really for 1:32 with the option of running a 1:24 for fun if needed. Ember, you say some sections, what don't you like or think will be a problem, this'll be a big one for me so want to get it right, all with experience is better than one with none. At the moment I am not sure about the far top right corner, it will be very blind I think hence the barrier to hopefully keep the cars on track in that section but cannot think of another way to introduce the hill climb. I'm also umming and aaaring over the corner to the left that goes below the squiggly bit, I'm worried that just behind it might be blind as well, hard to tell at this stage. The squiggly bit and the banked curve will be viaducts so hopefully that helps Quote Cheers Grant ....................................................... Home Track..........Corvette C1 Build..........McLaren M1A Build..........Maserati 300S Build..........Allard J2 Build..........50's Diner..........Iso Griffo A3C 3D Printed Adjustable Chassis..........3D Print Projects If life gives you lemons, take them, free s#!t is cool. Share this post Link to post Share on other sites
Ember 71 Report post Posted December 16, 2013 It's not a case of 'see a problem with' more 'don't excite me quite so much.' I love the switch backs on that end. This is the end that I like the most. I know it's done for space, but the short straight and sweep corner out of the switchbacks and onto the upper straight would work so much better if the corner could just continue rather than have that short straight and tighter section. The other things that don't excite me are the crossovers. Carnage area. But, that excites some others. I just see repair work and damage. Quote Computers. They'll never catch on. Tiny Tyers Targa - The build saga continues - Aging wood - A recipe for staining wood - Don't take a fence - Step by step paling fence - An old shed for my new cars - Wooden garage under construction Share this post Link to post Share on other sites
32coupe 20 Report post Posted December 16, 2013 Hi I was talking 1:32nd, and it only gets worse for 1:24th. The first track I built only had 50mm to the fence and it was hopeless, I now build my tracks with 100mm between lanes and 100mm to the outer fence, but only 50mm to the inner fence. Quote A man without a woman is like a neck without a pain. Share this post Link to post Share on other sites
shadow_rusty 41 Report post Posted December 16, 2013 Agreed with Andrew... Scaley track is quite narrow, and it's 77.5mm between the lanes, and 93.5mm to the fence with a border... I really wouldn't go any narrower than that... Quote Stolen from SlotsNZ Team ABC Team Leader (Ambitious, But Crap) Home Track Threads - Shadow's Semi-Permanent Layout & Another Rug Racer & Proud of It & Gymkhana Test Track Car Collection Thread - My Car Collection Charts / Diagrams - MJK Tyre Selector / Slot.it 4wd Gearing / PoliCar Rollout / Rollout Chart Generator / SCX 4wd Rollout / Track Wiring with Brake on Track Call Share this post Link to post Share on other sites
ZeGas 65 Report post Posted December 16, 2013 Fantastic, thanks for the advice, I think I'll just widen the corners and lead-in/lead-outs, I won't have enough space to widen the straights as well. I agree with you Embs on the crossovers, I'm not a big fan either, but without them there is a difference of around 1.5m in lane lengths. Quote Cheers Grant ....................................................... Home Track..........Corvette C1 Build..........McLaren M1A Build..........Maserati 300S Build..........Allard J2 Build..........50's Diner..........Iso Griffo A3C 3D Printed Adjustable Chassis..........3D Print Projects If life gives you lemons, take them, free s#!t is cool. Share this post Link to post Share on other sites
Ember 71 Report post Posted December 16, 2013 Wow. A metre is quite a lot. Quote Computers. They'll never catch on. Tiny Tyers Targa - The build saga continues - Aging wood - A recipe for staining wood - Don't take a fence - Step by step paling fence - An old shed for my new cars - Wooden garage under construction Share this post Link to post Share on other sites
Caddo 33 Report post Posted December 16, 2013 Just a suggestion, if you're going to race, think about marshalling. Costly experience is my teacher Quote Share this post Link to post Share on other sites
digby 1 Report post Posted December 17, 2013 G'day ZG , Your track kept me awake last night, Please think of getting rid of the crossed lanes and the corner in the corner.On such a technical track ,racelines rather than lane lengths can be more important (snigger).The crossover in the track is more important than crossed lanes ,I agree with the points raised by 32coupe, rusty, ember ,and caddo. But Have A Good Time,it's your track. regards digby Quote Share this post Link to post Share on other sites
Capri-corn7 104 Report post Posted December 19, 2013 I'm at paper planning stage too and know what you mean by number of iterations. Just wanted to say I love your idea of making the concept in scale first. Of all the many track builds on here & elsewhere, I don't recall seeing the track modeled first. I like this idea as you really see what you'd be getting. Thanks for the idea and good luck with the build. Quote They are only toys .... until you pull the trigger. Share this post Link to post Share on other sites
ZeGas 65 Report post Posted December 19, 2013 Hey CC7. Another good thing about the scale model is that if you use 3mm mdf you can also see how much flex there is for ramping, banking etc. Landscaping takes about 1/2 an hour with wet TP, then leave out in the sun to dry (about a week) to make sure it doesn't go mouldy. Geez Digby I didn't realize it would keep people awake, crikey. I've tried a few more options to get rid of the cross overs and they are, to say the least, crap. A must is to keep the switchbacks I really want a hill climb but am now seeing if I can raise it to the back rather than the front. Will post next iteration when I have something closer to what I think could work. Quote Cheers Grant ....................................................... Home Track..........Corvette C1 Build..........McLaren M1A Build..........Maserati 300S Build..........Allard J2 Build..........50's Diner..........Iso Griffo A3C 3D Printed Adjustable Chassis..........3D Print Projects If life gives you lemons, take them, free s#!t is cool. Share this post Link to post Share on other sites
kalbfellp 69 Report post Posted December 19, 2013 Andrew is very right about the clearance on the outside IMO 100 is the min. If possible try and aim for 110 on the exit from the corners. The fast Slot It and NSR cars with long tails will still probably hit the walls! Parts of Shelmore Park has 110 and they hit on the fast corners. Quote Phil Hobart Miniature Car Club Tassie Resins Email Share this post Link to post Share on other sites
32coupe 20 Report post Posted December 19, 2013 Ok, I figured out how you can get rid of the cross overs. At the end of the strait dip left and go clockwise around the corner and then come back down the short strait, then clockwise again for the next corner. Quote A man without a woman is like a neck without a pain. Share this post Link to post Share on other sites
ZeGas 65 Report post Posted December 19, 2013 You little legend 32 Coupe, guess who just earned themselves naming rights for the corner. That is the perfect solution, track still flows the way I want and both track lengths are now 27.75m. Well done Bro', now I'll widen the corners and tweek a bit then post up new design. Quote Cheers Grant ....................................................... Home Track..........Corvette C1 Build..........McLaren M1A Build..........Maserati 300S Build..........Allard J2 Build..........50's Diner..........Iso Griffo A3C 3D Printed Adjustable Chassis..........3D Print Projects If life gives you lemons, take them, free s#!t is cool. Share this post Link to post Share on other sites
32coupe 20 Report post Posted December 19, 2013 It's funny, but I saw that from the first time I saw your layout, it just took me a while to put it in a picture I could post up. Quote A man without a woman is like a neck without a pain. Share this post Link to post Share on other sites
ZeGas 65 Report post Posted January 1, 2014 (edited) Right, with Chrisy over I have found a few hours to have another look at the track and have come up with this, Both Lanes 23.889m. Will look at making a mock up model soon. Edited January 1, 2014 by ZeGas Quote Cheers Grant ....................................................... Home Track..........Corvette C1 Build..........McLaren M1A Build..........Maserati 300S Build..........Allard J2 Build..........50's Diner..........Iso Griffo A3C 3D Printed Adjustable Chassis..........3D Print Projects If life gives you lemons, take them, free s#!t is cool. Share this post Link to post Share on other sites
Ember 71 Report post Posted January 1, 2014 Yup. I like it. Quote Computers. They'll never catch on. Tiny Tyers Targa - The build saga continues - Aging wood - A recipe for staining wood - Don't take a fence - Step by step paling fence - An old shed for my new cars - Wooden garage under construction Share this post Link to post Share on other sites
ZeGas 65 Report post Posted January 1, 2014 Make that 30 degree bank, I'm cheating to try and get a longer straight Quote Cheers Grant ....................................................... Home Track..........Corvette C1 Build..........McLaren M1A Build..........Maserati 300S Build..........Allard J2 Build..........50's Diner..........Iso Griffo A3C 3D Printed Adjustable Chassis..........3D Print Projects If life gives you lemons, take them, free s#!t is cool. Share this post Link to post Share on other sites
dangermouse 95 Report post Posted January 1, 2014 that looks like a good track - lots of challenges - the bank turn will be fun to drive on Quote Share this post Link to post Share on other sites
32coupe 20 Report post Posted January 1, 2014 Now that looks better, your going to enjoy this track a lot more now. So what is holding you back now? come on I want to see a working model. Quote A man without a woman is like a neck without a pain. Share this post Link to post Share on other sites
digby 1 Report post Posted January 6, 2014 Well Done Guys, Now I can maybe catch up on some sleep and spend some time with My graph-paper. regards digby Quote Share this post Link to post Share on other sites
ZeGas 65 Report post Posted January 12, 2014 Well got a basic mockup done and already it has shown a problem, I think the straight needs to go through the viaduct with the return on top, At the moment the left hand end is a blind corner going down into the viaduct, I sort this out when I come to the full build. As for the full build, it will be in my shipping container, but that has to be cleaned out first. So I have the incentive, now just need the motivation, shame there are other things to do first or I'd get stuck in straight away. Quote Cheers Grant ....................................................... Home Track..........Corvette C1 Build..........McLaren M1A Build..........Maserati 300S Build..........Allard J2 Build..........50's Diner..........Iso Griffo A3C 3D Printed Adjustable Chassis..........3D Print Projects If life gives you lemons, take them, free s#!t is cool. Share this post Link to post Share on other sites
