kalbfellp Posted August 24, 2013 Report Share Posted August 24, 2013 (edited) Oz Rally is on again this year. It will also try some thing a little different to see how things go. Two class,s will be run with points allocated for each class. So we will have two winners. Rules for both class,s are below. I will start a new thread for entry list. I have tried to add all the eligible cars BUT may have missed some. OZRALLY PROXY SERIES 20013-14 RULES Historic Cars Series Description This year’s Oz Rally Proxy Series will be open to cars that competed in a Rally Championship before 1987. See list of eligible cars. Entrant's cars shall comply with the following rules. The onus is on the entrant to ensure that their car complies with the rules. There will be no allowances if you cannot make a particular model comply even if it is on the eligibility list. Please think carefully about your choice before deciding on what to enter. 1. Body a) Body must be as original RTR. No additional material to be used to modify the body other than updating wings etc as per 1:1 car. The body to be fitted with a 3 dimensional interior consisting of at least a driver and co/driver ( head and shoulders), steering wheel and 2 seats Vac form plastic is acceptable. c) All cars must have all windows, as fitted to the original 1:1 scale prototype. The window material must be transparent. Vac form plastic is acceptable. Plastic pieces glued individually to the window frame is acceptable but must be fixed securely to the body shell. d) No resin bodies allowed. 2. Wheels & Tyres a) Wheels are open to any brand but must have a wheel insert or be a one piece wheel with sufficient detail to represent the style of the period of the model. Rear Tyres are open to any eurethane or rubber tyre. i) Silicone tyres are prohibited eg; PPR Super tyres, Slot.it S1's, Puma Paws, Indy Grips, etc. ii) Foam rubber tyres are prohibited eg; tuna type. iii) Wheels and /or Tyres shall not protrude beyond the outer edge of the wheel arch opening Front tyres cannot be any more than 1mm smaller than the rears. 3. Chassis a) The original RTR chassis as fitted to original body of the car must be retained. If Non podded the motor orientation must remain the same. The chassic cannot be cut to add a pod. Traction Magnets are prohibited. c) Podded , inline sidewinder, angle winder, chassis allowed. Plastic pod and chassis Only. d) Chassis may be braced as required with a non metal material.eg plastic or PCB sheet. Brass, aluminum, steel or any other ferrous metal and carbon fibre are not permitted. e) Motor pod will be allowed this year BUT may be excluded in future years. f) Guide flag mount may be replaced but pivot point must remain as original g) Ground clearance - a starting clearance of 1.6mm is recommended under chassis with a minimum clearance of 1.2 mm under the chassis including the gear. (Last year two cars had clearance problems during the event). If your car does not clear the track it may not get run until the problem is fixed. h) The entrant's name must be indelibly written on chassis. Use either your forum or real name. i) Body screws should be retained within the chassis in a manner to stop them falling out. J) 4wd cars can be converted to run as 2wd. 4. Weight No limit on weight. Ballast must be firmly attached. Ballast fixed under the chassis must be completely covered with tape 5. Motors Open motor choice 6. Other Parts Open choice of body mount screws axles, gears, guides and braids. 7. Technical Inspection a) All cars will be inspected by the series director before the first round for compliance with the rules. The onus is on the entrant to ensure that their car complies with the rules at the technical inspection. c) Should a car not comply the entrant will have the option of having it returned to rectify or withdraw. Minor non compliances can be rectified by and at the discretion of the series director. 8. Modifications Repairs & Pre-event Checks To Cars During The Series. a) Once a car has passed a technical inspection its technical specification cannot be changed. Specifically: - Gear ratio. - Motor spec, - Guide type, - Wheel / Tyre size and compound. An allowance will be made before the series begins to correct a technical spec that is in breach of the rules In the event of a mechanical failure, components can be replaced but must be of the same spec as originally entered. c) If a car requires a tyre or (“racing”) braid change a 25 point penalty will be incurred. d) Body screws will be checked, bearings lubed, tyres and braids cleaned and set before each leg of the series by the track host. Tyres will be cleaned before each stage. 9. Series Point Scores Points will be awarded to each round as follows: file:///C:\DOCUME~1\PHILKA~1\LOCALS~1\Temp\msohtmlclip1\01\clip_image002.jpg 10. Conditions of Entry a) The entry fee is $10.00 AUD for Australian and International entries. Australian entry fee includes return postage. Overseas entries - return postage is additional to the entry fee and is payable at the completion of the event. The sole purpose of the fee is to cover postage costs (where applicable) of cars from one round to the next. Entries will close on 21th September. Entry fees must be paid by 21th September (4 weeks before start of first round). This is to ensure that people do not enter and then fail to send in a car, and denying others an entry spot. Entry fees are not refundable. Consideration may be given in exceptional circumstances and will be at the discression of the organiser c) Cars will need to be with the Series Director by 8st October for Tech inspection and allow sufficient time to rectify any issues with entrants cars. Please notify by Auslot Forum PM when cars have been posted d) Entries will be limited to 30 cars - One entry per person. e) Entrants will be invited to enter in the following order to prevent a first come first served scenario and people missing out because they weren't online at the right time. i. Those that entered last year and supported the event will have first option to enter again. ii. Australian and NZ members of Auslot who did not enter last year will be invited to enter next. iii. New International entries are welcome after that. iv. A reserve list will be used to fill vacant spots if required. 11. Postal address for sending cars and payment details Contact Kalbfellp for postal address and bank details. Pay Pal is available to entrants. 12. Misc. notes a) When sending car please do not use a plastic "crystal” case to hold you car. A small cardboard box with the car well wrapped in bubble wrap will suffice. Please do not send any spare parts with car as in the past they have had a tendency to go missing c) All cars will receive numbers (label paper stickers and will be attached to each car at round 1. Cars from last year will be allocated a number from last years finishing order). Entrants new to the proxy rally will be allocated numbers in sequential order upon receipt of entry. 13. Tracks and Hosting a Round a) Tracks are to be purpose built single or dual lane rally tracks. Multi lane race tracks with integral rally circuits are acceptable, provided the track is considered 'tight and twisty' and no long straights. Under no circumstances are rounds to be conducted on race circuits. Tracks are to have smooth surfaces. Elevations encouraged but extreme rough track surfaces that disadvantage some brands of car are not welcome. We are looking for a wide variety of makes and models and not a field dominated by one model only. c) The intention is to run the rounds at no longer than at 2 week intervals. Your round should be run by the next week end after the cars have arrived at your track. Forwarding on of the box of cars should be in time to arrive at the next host in plenty of time to run the round. d) Each days driving should be reported back to the forum when completed. e) An official score sheet should be completed and forwarded via e-mail to the director at the conclusion of your round. A template will be forward to you by the director before the commencement of your round. f) The postal addresses of next round host and reimbursement for postage costs will be forwarded to hosts by the series director at the conclusion of your round if required. g) Track owners are to run cars against the clock for a minimum of 8 minutes per round. You can break this up into as many stages as you like, for example, stage 1 on a Friday night, stages 2 and 3 on Saturday night and stage 4 on Sunday afternoon. An additional reputable driver (co driver) may be used to assist in driving at least one stage but must complete a full cycle of cars through that stage. The co- driver must be suitably familiar with the hosts track. Stages can vary in length and direction, just as long as the total time for the fastest cars is approximately 8 minutes. If you are unsure how many laps to run to total 8 minutes of driving - work out the best lap time you expect from a car in this field. Say 6.00 secs. How many laps will the fastest cars have to do be on track for 8 minutes. 8 minutess is 480 seconds so 80 laps total is a fair guess. 14. DISCALIMER Entrants should understand that no responsibility is accepted by the organisers, hosts or participants of the OzRally Proxy Series 20013/14 for the loss and/or damage to your cars or parts/equipment supplied either before, during or after the series is conducted. 15. OzRally Proxy Series 2013/14 Eligibility List This list of cars is not complete. Additional models maybe submitted to the organisers for consideration. The model must comply with the requirements as set out in the Series Description. Submissions should be supported by both documentary and pictorial evidence of a model’s suitability for acceptance in the series. After consideration the series director’s decision on a model’s acceptance to the list, shall be final and not open to appeal. Auto Art Sierra Lancia Fulvia Avant Slot Opel Manta 400 Renault Alpine A310 Fly Alfa RomeoGTAv Lancia 037 Porsche 911s Porsche 911SC Renault R5 GOM Alfa Romeo Alfetta GTV MRRC Porsche 911 Porsche904 MSC Porsche 959 Metro 6R4 Ford RS200 Ninco Lancia 037 Lancia Stratos Ford Sierra Porsche 934 Austin Healey Power Slot Opel GT Revell Audi Sport Quattro SWB Opel Ascona 400 Mercedes 220 SE Mercedes 300 SE Scalex Ford Escort Mk1 FORD LOTUS CORTINA MORRIS MINI COOPER Ferrari 308 GTB Holden L34 Torana 1976 MGB Ford RS200 Metro 6R4 Volkswagen Beetle Triumph TR7 Datsun 240Z Racer 240Z SCX Lancia Delta S4 FIAT 124 SPYDER Renault 5 Turbo Ford Sierra Cosworth Renault Alpine A110 Ford Escort MKII Renault 8 TS Talbot Sunbeam Lotus Seat 131 Abarth Seat 1430 Seat Panda Mini Cooper PORSCHE 911 Lancia 037 MGA Citroen DS 19 Sloter Opel Manta 400 Spirit Volkswagen Golf BMW 2002 Renualt 5 Turbo Peugeot 205 SRC Ford Capri RS2600 Team Slot Opel Ascona 400 Renault Alpine A310 Audi Quattro A1 Lancia Stratos Renault 5 Turbo Renault Alpine A110 OZRALLY PROXY SERIES 20013-14 RULES WRC Cars Series Description This year’s Oz Rally Proxy Series will be open to cars that competed in the World Rally Championship 1997 to 2013. See list of eligible cars. Entrant's cars shall comply with the following rules. The onus is on the entrant to ensure that their car complies with the rules. There will be no allowances if you cannot make a particular model comply even if it is on the eligibility list. Please think carefully about your choice before deciding on what to enter. 1. Body a) Body must be as original RTR. No additional material to be used to modify the body other than updating wings etc as per 1:1 car. The body to be fitted with a 3 dimensional interior consisting of at least a driver and co/driver ( head and shoulders), steering wheel and 2 seats Vac form plastic is acceptable. c) All cars must have all windows, as fitted to the original 1:1 scale prototype. The window material must be transparent. Vac form plastic is acceptable. Plastic pieces glued individually to the window frame is acceptable but must be fixed securely to the body shell. d) No resin bodies allowed. 2. Wheels & Tyres a) Wheels are open to any brand but must have a wheel insert or be a one piece wheel with sufficient detail to represent the style of the period of the model. Rear Tyres are open to any eurethane or rubber tyre. i) Silicone tyres are prohibited eg; PPR Super tyres, Slot.it S1's, Puma Paws, Indy Grips, etc. ii) Foam rubber tyres are prohibited eg; tuna type. iii) Wheels and /or Tyres shall not protrude beyond the outer edge of the wheel arch opening Front tyres cannot be any more than 1mm smaller than the rears. 3. Chassis a) The original RTR chassis as fitted to original body of the car must be retained. Traction Magnets are prohibited. c) No podded , sidewinder, angle winder, aftermarket or scratch built chassis allowed, plastic or otherwise. d) Chassis may be braced as required with a non metal material.eg plastic or PCB sheet. Brass, aluminum, steel or any other ferrous metal and carbon fibre are not permitted. e) No motor pod will be allowed this year. f) Guide flag mount may be replaced but pivot point must remain as original g) Ground clearance - a starting clearance of 1.6mm is recommended under chassis with a minimum clearance of 1.2 mm under the chassis including the gear. (Last year two cars had clearance problems during the event). If your car does not clear the track it may not get run until the problem is fixed. h) The entrant's name must be indelibly written on chassis. Use either your forum or real name. i) Body screws should be retained within the chassis in a manner to stop them falling out. J) 4wd cars can be converted to run as 2wd. 4. Weight No limit on weight. Ballast must be firmly attached. Ballast fixed under the chassis must be completely covered with tape 5. Motors Open motor choice 6. Other Parts Open choice of body mount screws axles, gears, guides and braids. 7. Technical Inspection a) All cars will be inspected by the series director before the first round for compliance with the rules. The onus is on the entrant to ensure that their car complies with the rules at the technical inspection. c) Should a car not comply the entrant will have the option of having it returned to rectify or withdraw. Minor non compliances can be rectified by and at the discretion of the series director. 8. Modifications Repairs & Pre-event Checks To Cars During The Series. a) Once a car has passed a technical inspection its technical specification cannot be changed. Specifically: - Gear ratio. - Motor spec, - Guide type, - Wheel / Tyre size and compound. An allowance will be made before the series begins to correct a technical spec that is in breach of the rules In the event of a mechanical failure, components can be replaced but must be of the same spec as originally entered. c) If a car requires a tyre or (“racing”) braid change a 25 point penalty will be incurred. d) Body screws will be checked, bearings lubed, tyres and braids cleaned and set before each leg of the series by the track host. Tyres will be cleaned before each stage. 9. Series Point Scores Points will be awarded to each round as: Once entries are conformed points will be sorted. 10. Conditions of Entry a) The entry fee is $10.00 AUD for Australian and International entries. Australian entry fee includes return postage. Overseas entries - return postage is additional to the entry fee and is payable at the completion of the event. The sole purpose of the fee is to cover postage costs (where applicable) of cars from one round to the next. Entries will close on 21st September. Entry fees must be paid by 21stSeptember (4 weeks before start of first round). This is to ensure that people do not enter and then fail to send in a car, and denying others an entry spot. Entry fees are not refundable. Consideration may be given in exceptional circumstances and will be at the discression of the organiser c) Cars will need to be with the Series Director by 8th October for Tech inspection and allow sufficient time to rectify any issues with entrants cars. Please notify by Auslot Forum PM when cars have been posted d) Entries will be limited to 30 cars - One entry per person. e) Entrants will be invited to enter in the following order to prevent a first come first served scenario and people missing out because they weren't online at the right time. i. Those that entered last year and supported the event will have first option to enter again. ii. Australian and NZ members of Auslot who did not enter last year will be invited to enter next. iii. New International entries are welcome after that. iv. A reserve list will be used to fill vacant spots if required. 11. Postal address for sending cars and payment details Contact Kalbfellp for postal address and bank details. Pay Pal is available to entrants. 12. Misc. notes a) When sending car please do not use a plastic "crystal” case to hold you car. A small cardboard box with the car well wrapped in bubble wrap will suffice. Please do not send any spare parts with car as in the past they have had a tendency to go missing c) All cars will receive numbers (label paper stickers and will be attached to each car at round 1. Cars from last year will be allocated a number from last years finishing order). Entrants new to the proxy rally will be allocated numbers in sequential order upon receipt of entry. 13. Tracks and Hosting a Round a) Tracks are to be purpose built single or dual lane rally tracks. Multi lane race tracks with integral rally circuits are acceptable, provided the track is considered 'tight and twisty' and no long straights. Under no circumstances are rounds to be conducted on race circuits. Tracks are to have smooth surfaces. Elevations encouraged but extreme rough track surfaces that disadvantage some brands of car are not welcome. We are looking for a wide variety of makes and models and not a field dominated by one model only. c) The intention is to run the rounds at no longer than at 2 week intervals. Your round should be run by the next week end after the cars have arrived at your track. Forwarding on of the box of cars should be in time to arrive at the next host in plenty of time to run the round. d) Each days driving should be reported back to the forum when completed. e) An official score sheet should be completed and forwarded via e-mail to the director at the conclusion of your round. A template will be forward to you by the director before the commencement of your round. f) The postal addresses of next round host and reimbursement for postage costs will be forwarded to hosts by the series director at the conclusion of your round if required. g) Track owners are to run cars against the clock for a minimum of 8 minutes per round. You can break this up into as many stages as you like, for example, stage 1 on a Friday night, stages 2 and 3 on Saturday night and stage 4 on Sunday afternoon. An additional reputable driver (co driver) may be used to assist in driving at least one stage but must complete a full cycle of cars through that stage. The co- driver must be suitably familiar with the hosts track. Stages can vary in length and direction, just as long as the total time for the fastest cars is approximately 8 minutes. If you are unsure how many laps to run to total 8 minutes of driving - work out the best lap time you expect from a car in this field. Say 6.00 secs. How many laps will the fastest cars have to do be on track for 8 minutes. 8 minutess is 480 seconds so 80 laps total is a fair guess. 14. DISCALIMER Entrants should understand that no responsibility is accepted by the organisers, hosts or participants of the OzRally Proxy Series 20010/11 for the loss and/or damage to your cars or parts/equipment supplied either before, during or after the series is conducted. 15. OzRally Proxy Series 2013/14 Eligibility List This list of cars is not complete. Additional models maybe submitted to the organisers for consideration. The model must comply with the requirements as set out in the Series Description. Submissions should be supported by both documentary and pictorial evidence of a model’s suitability for acceptance in the series. After consideration the series director’s decision on a model’s acceptance to the list, shall be final and not open to appeal. . AUTOART Citroen Xsara Ford Focus Mitsubishi Lancer Peugeot 206 Subaru WRX Avant Slot Subaru Mitsubishi Peugeot 207 But needs factory inline mount fitted. SCALEXTRIC Ford Focus Mitsubishi Lancer Peugeot 307 Renault Megane Skoda Fabia Subaru WRX Ford Fiesta RS WRC Mini Countryman WRC FLY No cars eligible NINCO Citroen C2, C4, Saxo Fiat Punto, Uno Ford Focus Mitsubishi Lancer Peugeot 306, 307 Renault Clio Seat Cordoba Subaru WRX Toyota Corolla Golf ( only for returning cars that run last year ) SCX Ford Focus,Fiesta, Festiva Citroen Xsara, DS 3,C4, C2 Hyundai Accent Mitsubishi Lancer Peugeot 206, 307 Skoda Octavia Subaru Imprezza Skoda Fabia Toyota Corolla Seat Cordoba Suzuki Swift Renault Megane TeamSlot Celica ST 185 Carrera Mini Countryman WRC Citroen DS3 Entries to be posted to: P.Kalbfell 2 Shelmore Drive Old Beach Tasmania 7017 Australia Edited September 6, 2013 by kalbfellp Quote Phil https://www.hobartminiaturecarclub.com/ Email Link to comment Share on other sites More sharing options...
alexis in greece Posted August 24, 2013 Report Share Posted August 24, 2013 (edited) Quote f) Guide flag mount may be replaced but pivot point must remain as original Are one of the following accepted: -Guide part from HRS chassis -Guide part from PCS chassis -or any similar part -B-nova -home made plastic construction -Metal plate ,say 20x20 mm, and tube Edited August 24, 2013 by alexis in greece Quote Link to comment Share on other sites More sharing options...
kalbfellp Posted August 24, 2013 Author Report Share Posted August 24, 2013 Alexis pivot must be in original position, any plastic replacement guide pivot OK. Metal pivot no. Quote Phil https://www.hobartminiaturecarclub.com/ Email Link to comment Share on other sites More sharing options...
charlesx Posted August 25, 2013 Report Share Posted August 25, 2013 My new Scaly Ford RS200 has a width of about 55mm so is close to scale width. Have not checked other dimensions yet. Regards Chas Le Breton Quote Link to comment Share on other sites More sharing options...
miveson Posted August 25, 2013 Report Share Posted August 25, 2013 Can you update the points jpg Phil - then the work can begin. Quote Slot Car Photos V8 Tipping Competition Link to comment Share on other sites More sharing options...
Peter Gunn Posted August 26, 2013 Report Share Posted August 26, 2013 Phil WRC can i use MSC CARS. Quote Link to comment Share on other sites More sharing options...
kalbfellp Posted August 27, 2013 Author Report Share Posted August 27, 2013 (edited) No, the MSC WRC cars I have looked at are all podded. Read the rules as I had transposed part of them. Last year Ninco and Avant were the popular choice. Edited August 27, 2013 by kalbfellp Quote Phil https://www.hobartminiaturecarclub.com/ Email Link to comment Share on other sites More sharing options...
charlesx Posted August 28, 2013 Report Share Posted August 28, 2013 Hi Phil - more silly questions. Am I allowed to modify or remove original engine mounts to fit different motor but retain same orientation? For example may be required if I want to change gearing. Secondly do any replacement bearings need to be able to fit into original bearing holders or can bearing holders be altered as long as not shifted. Regards Chas Le Breton Quote Link to comment Share on other sites More sharing options...
kalbfellp Posted August 28, 2013 Author Report Share Posted August 28, 2013 remove original engine mounts to fit different motor but retain same orientation? Several people have done this in the past, Ninco into SCX etc So Yes. Secondly do any replacement bearings need to be able to fit into original bearing holders or can bearing holders be altered as long as not shifted. I cannot see why this would be required. Most people just open out the bearing holders IF the replacement bearings are bigger. Quote Phil https://www.hobartminiaturecarclub.com/ Email Link to comment Share on other sites More sharing options...
charlesx Posted August 28, 2013 Report Share Posted August 28, 2013 Ta for first. Just being thorough. I have no idea what people have done in past. On second agree can probably just be drilled out but needed confirmation because of previous comments in earlier Oz Rally. You can buy brass compatible bearings but I wanted to use something else if I do not retain Scaly plastic ones. Regards Chas Le Breton Quote Link to comment Share on other sites More sharing options...
Freddie_Vanger Posted September 5, 2013 Report Share Posted September 5, 2013 The inline permitted? Quote Link to comment Share on other sites More sharing options...
kalbfellp Posted September 5, 2013 Author Report Share Posted September 5, 2013 Yes Freddy Inline only in WRC, hot setup the last few years has been Ninco with either NC2 or NC 5. But there have been a couple of good SCX cars over the years. Quote Phil https://www.hobartminiaturecarclub.com/ Email Link to comment Share on other sites More sharing options...
Freddie_Vanger Posted September 5, 2013 Report Share Posted September 5, 2013 Yes Freddy Inline only in WRC, hot setup the last few years has been Ninco with either NC2 or NC 5. But there have been a couple of good SCX cars over the years. Thank you for the information. Quote Link to comment Share on other sites More sharing options...
ntz Posted September 5, 2013 Report Share Posted September 5, 2013 "1. Body a) Body must be as original RTR. No additional material to be used to modify the body other than updating wings etc as per 1:1 car." For WRC. Can we remove non essential parts for securing them from being broken?? For example mirrors, wings, night lights (peugeot 207 Avant) etc. Or the body must have everything on it??? "2. Wheels & Tyres Front tyres cannot be any more than 1mm smaller than the rears." For Historic: 1mm smaller, meaning the whole diameter of wheel and tyre??? Or just the tyre??? Quote / / www.106sportclub.gr /www.trackday-special.gr Link to comment Share on other sites More sharing options...
kalbfellp Posted September 5, 2013 Author Report Share Posted September 5, 2013 (edited) The outside diameter of the tyre when fitted to the wheel, this is to ensure that very small low profile front tyres are not used. Edited September 6, 2013 by kalbfellp Quote Phil https://www.hobartminiaturecarclub.com/ Email Link to comment Share on other sites More sharing options...
charlesx Posted September 6, 2013 Report Share Posted September 6, 2013 Hi Phil. Do you mean not used? Chas Le Breton Quote Link to comment Share on other sites More sharing options...
kalbfellp Posted September 6, 2013 Author Report Share Posted September 6, 2013 That's what it does say Charles!! LOL Quote Phil https://www.hobartminiaturecarclub.com/ Email Link to comment Share on other sites More sharing options...
branco Posted September 6, 2013 Report Share Posted September 6, 2013 Hi Phil, I have a situation!! Am on holiday from 12th sept until 27th sept. I will miss the 21st sept closing date for entries and if any decision on entries allowed for both classes. Can you pm paypal details so I can send at least 1 car your way soon. cheers. Quote 2019 NZ RTR Nationals Gt 3rd 2017 NZ RTR Nationals NSR Classic 2nd 2017 NZ RTR Nationals Group C 3rd 2017 NSR Classic Challenge 3rd 2015 NSR Classic Challenge 2nd 2014 NSR Classic Challenge 3rd 2015 Garden City Invitation Overall Champion Link to comment Share on other sites More sharing options...
charlesx Posted September 6, 2013 Report Share Posted September 6, 2013 Thanks Phil. Did you edit or am I going sillier. I am sure I read it at least 6 times. All clear now even in my fussy mind. Chas Le Breton Quote Link to comment Share on other sites More sharing options...
kalbfellp Posted September 6, 2013 Author Report Share Posted September 6, 2013 Postal address added to the bottom of post no 1. Charles Would I do that? LOL Quote Phil https://www.hobartminiaturecarclub.com/ Email Link to comment Share on other sites More sharing options...
charlesx Posted September 6, 2013 Report Share Posted September 6, 2013 Hi Phil. I will have to accept that I am seeing things or more accurately not seeing things. Ta for address. Hope you have warned postie we expect better performance next time. If I remember correctly last time car took nearly a month to get to your address. Should not take more than a week. When will decision be made on classes? Still hoping you will run both but really enjoying chance to build new car for Historic. Regards Chas Le Breton Quote Link to comment Share on other sites More sharing options...
aquakiwi Posted September 6, 2013 Report Share Posted September 6, 2013 Hi Phill I'm considering an entrant if I can get it up and running in time, a couple of questions from a "newbie". Can ballast be brass or lead(if covered in tape) and can alloy wheels be used? Quote Link to comment Share on other sites More sharing options...
kalbfellp Posted September 7, 2013 Author Report Share Posted September 7, 2013 I would recommend using alloy wheels at least on the rear,preferably fitted with eurethane tyres. Brass or lead is fine,if under the chassis needs tape to insulate it. If on top of chassis it does not need taping. Quote Phil https://www.hobartminiaturecarclub.com/ Email Link to comment Share on other sites More sharing options...
aquakiwi Posted September 7, 2013 Report Share Posted September 7, 2013 I would recommend using alloy wheels at least on the rear,preferably fitted with eurethane tyres. Brass or lead is fine,if under the chassis needs tape to insulate it. If on top of chassis it does not need taping. That's what I wanted to hear, thanks. Quote Link to comment Share on other sites More sharing options...
charlesx Posted September 11, 2013 Report Share Posted September 11, 2013 Hi Phil - another silly question. Do not think it is mentioned. My apology in advance if it is. Are rubber tyres allowed to be treated for Oz Rally? This has been a real contention in NZ and has caused a little tension. Possibly only appropriate for the smooth tracks we generally have in NZ but I would like clarified please. As example of local rules treatment was allowed at NZ Nats for first time earlier this year because organiser said he could not police. It is not allowed however in Canam Proxy in which you have been regular competitor. On wear my Canam car has now used the same NSR Ultra tyres for the last three proxies and is still performing well. Another car I built has 2 year old tyres. Thanking you. Regards Chas Le Breton Quote Link to comment Share on other sites More sharing options...
