dangermouse
Blue Ridge Parkway - 2 Lane Routed Track
Happy to provide any tips - for the grass in front of the wall I put a lot of thin strips of white glue on some baking paper and then sprinkled grass with the static grass applicator, once it dries it makes some really nice strips and is easier to put down than trying to stick the grass on the spot.
I checked with PlastaMasta and Gyprock who both do insulation as well as plaster, we don't have a Boral agent here in town, and neither knew what the hell I was talking about even when I shoved a sample under their noses. Of course, being here as distinct to anywhere else, neither would investigate further on my behalf either.
I started working on a little stone walled overlook.
A55B7915-4B3F-472C-A608-9A5A22661419_zps
A7382499-6652-4BEE-93B9-574DA049B6C5_zps
I have also started working on the viaduct wall. Construction is blue foam cut and shaped and then coated with some joint compound.
FADD8AD0-B49F-4E7E-86F1-37DD7F845483_zps
Edited by dangermouse
Some progress on the tunnel
Ok well started on fixing up the last remaining hole in the scenery
I used a high density foam core board for the tunnel entrance - scribed with a pencil - coated in white glued and then sprinkled with sand for texture. Once dry paint grey and dry brush with a lighter grey and white.
I probably made the tunnel entrances bigger than they need to be... I didn't want the cars hitting them though
78E9FF27-AFE8-4513-8840-04395D9E2DEE_zps
02E83E8D-C293-4158-A51D-E4B4B48B691A_zps
0896500E-B4D4-46D2-8096-1585B747B25E_zps
Been a while since your last post on this one I thought it was a dead duck, The bridge is coming along very nicely indeed.
Is the radius of the curve inside it likely to cause a problem with cars coming off or, can you hoon without issue or, will the momentum of a derailed car just conveniently slide out.
In any case I look forward to more updates.
I have been busy making cars - I think I discovered resin kits about the time of my last update :)
A new driver to the track might come unstuck - if anything you are more likely to come off once out of the tunnel as there is a slight camber there that can cause grief if you drive to fast.
The car is in the tunnel for about 1/2 of a second plus the track is more of a driving rather than racing track so if you loose it in the tunnel you will slide out most likely.
I'm with you there, I much prefer driving a car than racing one, it is nice to see a car fishtailing around corners and not have someone saying "you know fishtailing will slow you down" I know but it looks good and is fun.
Have you put any of your cars up that you have built I don't recall seeing any.
Shows my ignorance I did see them not the Alfa though, lovely work on those too,
great hobby huh.
Some modelling, engineering, landscaping, woodwork, electrical, cursing, swearing, it has it all.
Wow, just came across this thread David. Very impressive, and great progressive build detail. Now we need you to post a series of shots or a vid showing the completed product. :D
Well it has been a while since I updated the track pics...
I did some work on the tunnel area - nearly done just need to add some grass to the tops and it will be all done....
E553EF0E-4DC6-4323-B763-5BA0C3911607_zps
97DD0016-D06E-4EA0-A310-2FAFF21866EC_zps
5BFBD55F-EDDF-4AE9-A79F-F50D6CAF685A_zps
DB909146-148F-48F8-8B5C-F40BFFFF8723_zps
44331289-8685-4C59-B851-E5B08E2F5FC2_zps
Nice work
2019 NZ RTR Nationals Gt 3rd
Love the track, Love the era.
Well done DM I think you are setting the standard for landscaping.
'Blue Ridge Parkway' huh? ... nice name and it looks like a pleasant drive to suit.
Grassed the knolls and added some trees - 97% done now - some fine detail bits such as a wooden fence and some cabins to add - that is if I stop getting distracted running cars :)
80628A22-6587-420D-BF7D-F39D6930E016_zps
F00735D7-D4C9-4983-B492-72AE9A1D946D_zps
