neil
Powering Light Bridge & Other Lights Around The Tracki
1st,,Q). would there be a prob. in running many many(led) lights from the same power the cars are running from... Have a variable Power suply,, plenty of amps,,,,, 2 cars running @ the most.
just dont want to overload one power lead with multible power sources/outlets/plugs
You may have a problem with fluctuation in the lighting as the cars draw current from the same source.
I am about to construct some lighting around my track and was going to use a separate system one for the cars only then another for the rest of the electrical work around the track.
Must admit though that I am a bit of a novice and just learning my way through the electrical world, with plenty of help for others on this site.
Running leds on the same power source shouldn't be a problem though as they only work off 2.5v or 3v and only a couple of mA so won't overload the circuit.
My humble opinion only.
"You may have a problem with fluctuation in the lighting as the cars draw current from the same source."
exactly what I'm thinking "will" happen,,,,,,,, But again thinking It "should'nt ............ A trip to the Jaycar fellas will hopefully sort me out
Provided you are using (as you should), a regulated power source, then any movement in voltage will be small, and measurable only in milliseconds if you are using normal., modern switch-mode type power supply.
Try and get at least a 5 amp supply for your 2 lane track.
LEDs should be each wired with a resistor on one side of their feed wires, and the value of that resistor is determined by the voltage of the supply - lets call this one 12 volts, and by the amount of current you WANT the LED to draw as appropriate to it's rating.
eg 20 milliamp is a common rated capacity for 3 and 5mm LEDs.
For that particular combination you would use a 470 ohm resistor, or a 560 ohmm resistor, resulting in sllghty over or under 20ma draw at 12 volts.
You just vary the resistor value used according to the parameters above - and also, if you want some LEDs dimmer, just use a higher value resistor....
well all is good as far,,,,,. Made a temporary light bridge so I can run the R/C,, I purchased the IR lights a while back & was unsure of the discusion @ the time,,, anyway unearthed the pakage & had resistors with.... all is good. In my journeys I've also unearthed a bunch of taffic lights that I purchased,,,, & they too are workin better than my expectations...... So now it's a definite trip to jay car to look for a simple switch with 3 funtions that can be operated @ 2drivers & posibly a 3rd/marshall point.
