Keith Posted October 30, 2012 Report Share Posted October 30, 2012 Hi guys, i am having trouble with my sports digital track, it is kept clean, it works great for the most part, one lane is super fast and the other is about 60%, you can fly around when all of a sudden it goes slow for a certain distance and then off it goes again, i have taken it apart, replaced sections, and checked joints, i really do not want to start soldering wire to it and i obviously do not need to fit jumpers as it only affects a small area always on the same side, does any one have any suggestions, i am aware that i can turn it over and squash each joint to supposedly make better contact, but i have also heard this can damage it as well, i dont want to run copper tape as i may want to change the lay out. Quote Link to comment Share on other sites More sharing options...
miveson Posted October 30, 2012 Report Share Posted October 30, 2012 Keith, Buy yourself a Multimeter $5 at Jaycar and you'll easily find the areas of the track that are giving you the trouble, you can try and fix or simply buy a new piece. I had very similar issues but was able to identify with the multimeter a couple of track pieces that would on occassion cause issues, replaced and vola, everything good. Whilst your there get yourself some inox and give the rails a good wipe down - you'll be surprised at the difference it will make (careful not to put any on the track as the lubricant will cause all manner of slides. Mark Quote Slot Car Photos V8 Tipping Competition Link to comment Share on other sites More sharing options...
Keith Posted October 30, 2012 Author Report Share Posted October 30, 2012 I actually do have a multi metre, not exactly sure how to read it but i will give it a go thanks, i do have INOX already and have kept it clean. Quote Link to comment Share on other sites More sharing options...
RikoRocket Posted October 31, 2012 Report Share Posted October 31, 2012 Jumpers is the best solution, dodgy connections can be a nightmare to solve. At the world record scalextric speed trial a few years back the scalextric rep had a home made tool for tweaking all the joints - a bit like a wide flat screwdriver that he twisted at each end of the track. He still had about 10 jumpers as well. Quote .............................PM me for C7042 Aux to PC cables............or Pit-Pro... Link to comment Share on other sites More sharing options...
