brityank
Cox Chaparral 2D Project...
It's been a while so I thought I would drop this on the forum. Needless to say. it's a Cox Chaparral 2D that I'm working on among many other projects which I'll put up when done real soon.
The first thing I wanted to do with this car was to lower the car to a better stance. In order to that you have to cut the interior down (check photos) along with the posts. The good news about dropping the interior is that the wires from the motor fit better under the interior. I'm not using the original headlights so I have filled in the holes. I'll use a more realistic set of lights. I also fitted the black wrap for the windows. These will be fitted with rivets later. The body is not done yet but half way there. More details will be added. The chassis will be sand blasted along with the wheels. This car should look pretty good when it's done.
Edited by brityank
Nice to see it in the undercoat...great photography too.
I'm sure we will see more...I want to see more.
Thanks lads
Update...
Building the rear spoiler. All I did here was use a piece of styrene and cut it down to size. Sanded the edges down cut 4 slits even across. I found some old round small etched hood hinges with holes in the middle and placed rivets in the middle of them. I then lined them up and glued them into place and then cleaned up the back of the spoiler. I've added scratched built door handles which I'll remove and add to the finished body later. You can see I've already started to clean up the body some more and I will do more clean up later before painting.
Please keep in mind that this is not meant to be accurate and there will be some exaggeration
More detailing to come
Onward...
The photo of the chassis took me back to when I was in primary school... Thanks. :)
[edit:] The magnesium Cox chassis that I had back then was just the ducks guts to me, I would so love to still have it.
Edited by inveterate retiree
Another excellent job ....... keep em comin
wow, to me a single lap around my favourite track (slowly and without anyone else withing 10 metres of a controller) just to show it works and straight into the display case...
unfortunately I'm new to this forum and all of your older projects are no longer visible so I can only guess what the quality of those is like, any chance of getting those images back on line (not linked but as a catalogue)?
Stunning , simply stunning . Anyone who has ever done figure modelling will know getting the eyes right and not having them look like fried eggs is almost impossible .
