Routed Track Problems
2 replies to this topic
#1 Nils
  • 20 posts
Posted 18 December 2010 - 03:40 PM
Hi guy's,
i recently bought a routed track. Finally i now have cars and controllers( Aussie V8's).
Unfortunately the track has a couple of dead spots and some slow spots.
I suspect that the legnth of the track has some thing to do with Slow spots, and that there maybe some breaks in the track which are causing dead spots.
I can't see these breaks with my poor eyesight.
Is there some logical basic testing i can do???
And how do i go about it???
Any other ideas???
Thanks, nils
#2 dangermouse
    Kart Racer
  • 3,840 posts
Posted 18 December 2010 - 03:56 PM
I assume that it is copper tape. When I get a dead spot to locate where the break might be I power on the controller (have some one operate the controller while you move the car or if you have one use a multimeter) and move a car around until it stops I then check the opposite end and find where the car stops there then it a matter of looking for anything that might indicate a poor connection. I solder a piece of copper tape over the top of the break. Have fixed it every time so far.
Not sure about the slow spot - my track is 6.5m long by 1.4m wide and I only have 1 power connection without any problems
#3 gzminiz
    Newb slotter
  • 909 posts
Posted 18 December 2010 - 04:44 PM
Check the terminal blocks. There are three taps front straight middle and the back just after the tunnel. Also try cleaning the tape with inox or shellite. If u hold the continued on at full power and take a volt meter to both rails u should get close to thesame voltage reading as the driver station. +/- .2volt
