Yngwie
Using Plywood Instead Of Mdf
I was just wondering (must build rally track) othr than cost, is there any reason no one is routing tracks on say 9-12mm plywood? It offers significant advantages in terms of weight. For a portable track it seems the go but what do you think?
It's generally more expensive per metre, more fragile, and more difficult to work with due to the fact it's glued sheets of wood, not just a sort of glue all by itself. It shouldn't chip on the slot when you are routing it if you use a sharp bit and a lot of speed.
I would have thought it would be almost as heavy as MDF anyway.
The difference in weight between MDF and Pine ply is quite minimal
MDF Average Density - 4.609g/cm3 or 4609Kg/m3
Pine Ply Average Density - 4.881/cm3 or 4881kg/m3
and contrary to popular belief it is usually heavier than MDF of similar volume
(My students do this stuff as part of their course)
so there really is no reason to go for ply as previously stated no matter how sharp the router bit is it will almost always "break out" the grain when routing across the grain. Not to mention that unless you buy expensive ply the surface will contain imperfections. (OK for a rally track i surpose)
on the flip side at least it is not a known carcienogen like MDF (Make sure you wear a dust mask)
Cheers Gloveman
I rather push my Datto than drive anything else!
Routing Ply does not give very good results as at all times you are cutting across some grain. Chipboard used to be used to be used for tracks before MDF was on the market,just not as good a material to route. The first HMCC track back in the sixties was made from masonite.
Ok, thanks guys. You have managed to change my mind. By the way, I will post some pics of our schools drag strip. We have made it 15m in length and the kids absolutely love it!
Ply tends to splinter when bent or twisted unfortunately. Did you know that MDF stands for "Maintains Defined Formation". Sorry guys that the best I can come up with, do we have any other suggestions??
Gort, Klaatu barada nikto.
My poor Krell!
Mostly Deviate Fellows
Perhaps seeing as it's Friday Frivolities tonight for the Ballarat boys that should be
Mainly Drunken Friends
